I suggest you model the goods by creating solid bodies that are set to be Rigid.nYou would model the EPS between the solid bodies and the container walls. You can potentially create the body using a Boolean subtract from the goods for a block that fills the space of the container.nDo you will need material properties for EPS foam including the damping properties for EPS foam.n
