Yes, it is possible, whether it is necessary is a different question.nIf your materials have creep properties that come into effect at these short time scales, then you would want to simulate the true time the test takes.nBut if your materials do not have creep properties, then time is irrelevant. Only displacement matters when things are moving this slowly.nIn either case, you solve the model in Static Structural.n
