francescone96
Thank you for the fast reply Sdeogeka. nThe radial expansion is not totally blocked, because this is just a simplified model, but around the external tube there is other aluminum. The constraint i want to apply is in between the fixed support and the free-surface. nAnyway thank you very much for the attempt!n
