DrAmine
Either you do the post-processing inside Fluent and there you need to start with at least -gu .driver null or to post-processing separately on the cluster using CFD-Post or EnSight. I am not sure if your cluster management allows you to do interactive things. For that reason you always can use batch post-processing with CFD-Post.n
