Dragana Jandric
I am not sure what do you mean you would like to see the dimeson of the other parts? In the table of design points you will only see the parameters. You can set the design point as current in the table of design points in order to see that design in Mechanical. You would need to update the current design point. nArraynnThe other option is: If you want to see how the results/design of a certain DP looks in Mechanical you can check retain in the table of design points before solution. Once you get the solution you can do right mouse click on the design point and export design point. In the working directory you should see wbpz file that you can open in Mechanical and see the geometry and results for the exported design point.nArraynn n
