Judy Cooper
Hi Anastasiia :nIf your run hasn't failed for system reasons, ie: insufficient memory or MPI not set up, you will find a log file called FORTE.log in the run directory.nFor most projects, the run directory is ..\Projectname\FORTE-projectmame.analysis\Nominal.nThe Forte.log file gives a detailed account of both the job start up command, job inputs and what happened during the run. n
