You can copy injections, which makes it a bit simpler. In the tree you can also export the injection, the format's a bit messy but if you know what the GUI setting was you'll be able to find the numbers and then manually adjust each injection (not ideal) or, finally, use a TUI journal to create the injections. I'd favour the latter approach as once you have the syntax you can create a journal very quickly. n
