November 24, 2020 at 11:24 am
Ansys employees can not debug user scripts on the forum, but I will try to give you some best practices which may help.nI have not used sublime, so not sure how that works for codes but some other tools have a quick function to convert all leading spaces to tabs or vice versanin python indentation is very important so choose either spaces or tabs as indentation method and stick to itnAlso, make sure if your python file is correctly named as me.py that is stored in a folder which is at the same level of the xml filen-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
