nThe model with the rotation to be Free on the Z axis of the Remote Displacement and the same Initial Angular Velocity as described above resulted in erosion.nHere are the erosion controls:nWhat do you suggest?n
New Post - Reply To: A solid tube rotating at a constant 350 rpm erodes itself, why?
