The erosion strain is too small. Try the default: 1.5.nThe alternative way to rotate a body is creating a Revolute Joint connection and then using Joint Load to rotate the geometry.n
New Post - Reply To: A solid tube rotating at a constant 350 rpm erodes itself, why?
