Can you elaborate on the issue?nHow are you starting Workbench? nAre you running from a remote machine?nAre you using a Terminal emulator? If so, which software?nAre you receiving an error? If so, what is the error?.
New Post - Reply To: Unable to start the meshing editor and mechanical editor in workbench
