nYou can't simulate compression-deflection on rubber unless you have a material model. The best way to get a material model is to obtain material test data from a lab that knows how to do these material tests.nDo you have samples of the material in sheet form?nDo you have the resources (time and money or access to a testing lab) to acquire material testing data on those samples?n
