November 25, 2020 at 5:42 am
For running calculation it is not required to reduce face quality to 0.2. nDepending on your geometry, if you try to collapse faces till 0.2, it may distort your geometry. You can see it by displaying and inspecting geometry. nPlease improve surface mesh till 0.7 only. That means you will not have any surface mesh with skewness above 0.7. This should be good enough. nPlease see help manual for more details about these commands. nnRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
