November 25, 2020 at 5:55 am
thank you for answering.nAre there any research papers or books which you can kindly recommend which explains how and where to modify the structure according to the loading and failure type. How to incorporate the effect of load paths and alter the geometry accordingly so that the stresses can be gently distributed without causing any failure?nMy question was actually this; for example I use Von-Mises stress, now that will be a combination of all kinds of stresses, but I want to know which type of stress (like tnesile or compressive or shear) at the location where Von-Mises stress is higher than the yield strength, has the most effect on the Von-Mises stress. Is there any option to know that in ANSYS?n
