November 25, 2020 at 10:06 am
That is well converged one sir , but I need to update one , I run simulation both the cases as pressure based approach and density based approach , nfor steady case approach , temperature is not existing the inlet temperature ..there its finenin transient approach , if i use constant inlet with pressure based approach .. temperature is not more than inlet temperature nbut when i use variable pressure boundary at inlet ..its more than inlet temperature for the both pressure and density based approachesnso please help me to resolve this issuesnn
