November 25, 2020 at 10:12 am
Of course, I started this work because of an article. I can share the article with you. There are experimental studies and there is another program, abaqus program solution, but only for the part up to the initial torsional load. I am sharing the article link and abaqus solution link with you. But in the experimental data, we noticed that the pressure values in the article are 10 times bigger. There was probably a mistake.n
" target="blank">nRegardsnOguzhann
