If you don't turn on data sampling there is no RMS data calculated. The current velocity is what you are seeing. nFor a transient case, and assuming a mean velocity is a valid value run for a while (ie until the flow field is stable) and then turn on the sampling and run for a while more (ie a few flow cycles). n
