Mike Rife
Hi - the nodal value will take into account the element volume apportioned to the node for all elements the node is attached to. If you prefer to work with element data then change the 'Display Option' to Element Mean. This will give you a single value per element. nTraditionally when doing the Darveaux fatigue calculation we would have used a post-processing commands object and used a ETABLE [element table] to gather send,plastic.nMike n
