ANSYS_MMadore
Array Can you try renaming your %APPDATA%\Ansys\vXXX directory to vXXX.old, where vXXX is the version you are trying to run? If that fails, please open a command prompt and enter set without the quotes and send the entire output.nnThanksnMattn
