DrAmine
(Turbulent Dispersion Force + Sato Enhanced Viscosity) both turned on will massively impact the flow behavior of the air bubbles. But if this enough to push the bubbles towards the heat sources: I am not sure. Are you repeating a paper or experiment? How do you know about the bubble size?.As mentioned: VOF Volume Fraction is required to understand but we cannot do much here.n
