nCongratulations on a successful model.nIt is easy to plot the contact pressure, using the Contact Tool inserted into the Solution branch. The contact force needs more work. I can't give instructions on how to do that without first doing some research. Please Save As your model, and in that copy, delete the solution and the mesh and create an Archive file. You have to put that in a Zip file, then you can attach it to your reply. Say what version of ANSYS you are using.n
