smalbro93
No, just that you'd need to do data sampling. Steady state is the equilibrium case, so, in theory all the results are averaged (look up what RANS means).https://forum.ansys.com/discussion/comment/98489#Comment_98489
Hi Rob, thank you for replying. I understand that for steady case, the obtained wind velocity is already the mean velocity. So that means when I generate Velocity Magnitude contour, it itself is the Mean Velocity Contour right? Or do I run the Steady Case first and then then do Data sampling with Unsteady to obtain the Mean Velocity Magnitude?n
