Try the new shared topology method in the Workbench tab of the SpaceClaim instead of changing it in details under part.nIf you ok with contacts, you can use the bonded contacts instead of shared topology.nAnother alternative would be imprinting all the faces in SpaceClaim and bring in with shared topology None (and without the new shared topology method) and use same mesh size and later use node merge operation in Mechanical.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
New Post - Reply To: Geometry import in Mechanical taking a long time when shared topology is used
