The velocity contour is the velocity field for that iteration in steady state. Data sampling can also be done on a steady case where we may see some slight changes in the flow (you'll have poor convergence) which can then produce an averaged velocity field. nAs well as needing care with the set up & physics simulation also needs care with language: a term we use may not be understood in the same way by everyone. n
