Federico2594
Hi Aero2020,nDo you have evaluate your mesh?nI think probably that the mesh is not good to describe your phisic problem. Are you in Grid Indipendent solution?nDo you have evaluate your y+ for your turbolence model? Is the inflation layer correct? nDo you begin the calculation with first order to prepare the solution field and than change to second order?nWithout being presumptuous i think you have to see the theory before and then start the calculation.nRegards,nFedericon
