November 27, 2020 at 11:53 am
Hi Rob,nfor example speaking of a car wing formed by two profiles i'can't insert the parameter between the distance of two parameters in DM because i imported my curves from .txt file (And they aren't sketch components that guarantee to set the distance as parameter).nSo in DM i insert the AOA of the entire wing (selecting the two profile--> Rotate Tool --> ParameterAOA); this in Space Claim (for what i tried) is not possible because the geometry blowed up.nSumming Up:nin DM i insert my AOA of entire wing (this blow up in SC)nin SC i insert the distance between the two profile (that is not possible in DM because the profiles are curves, not sketching components)nBut now, the parameters form DM to SC disappears.nnRegards,nnFedericonn
