November 28, 2020 at 2:53 am
ArraynThese are very slow loading rates so this is best analyzed using Static Structural.nIn Static Structural, time is not real, but used to keep track of the percentage of total load, so 1 second is often used as the time to apply a load. 1 second = 100% of the load.nWhat kind of material is the beam made from? What are the properties of that material? Is the material ductile or brittle? Do you know the yield strength of the material? If the material is ductile, do you know the stress-strain curve of the material?nWhat is your definition of failure?nWhat does 20.5 f mean?n
