nConverting geometry between systems often has problems. You exported lines from SolidWorks to IGES. If you import that file back into SolidWorks, do you get all the lines?nDo you have SpaceClaim as well as DesignModeler? In SC, you can import solid geometry and convert them to beam. You can see if SC imports the IGES file better than DM.n
