November 28, 2020 at 7:11 pm
nPlease use the Windows Snipping Tool to get a screen snapshot. Don't use your cellphone camera to take a photo of the monitor, it is a bad image and a large file size.nDid you add plasticity to your material model and did you assign that material to your body?nStatic Structural analysis as described above can do the non-linear buckling. It helps if you add a small amount of the buckled shape into the initial geometry (or mesh) to give the solver an initial imperfection in the geometry.nThese models most easily converge if you apply displacements to the beam. You can plot the reaction force to know how much force is being put into the beam. The experimental specification of force/minute doesn't apply to a Static Structural analysis.n
