nFor a solid element, a Fixed Support is the same as a Displacement with X, Y, and Z = 0. It is simpler in a multistep analysis to change a Displacement from 0 to non-zero between steps. You can also use two Displacement BC, one with Y and Z = 0 and another with X = 0. In that way you can changes just the X value between steps.n
