November 30, 2020 at 3:11 am
Hi Rene,nSorry to hear about your head; I'm sure we can help you out.nI'm seeing some differences with the names in the inputfile.py and the instructions in the tutorial here. https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/sysc_tut/sysc_tut_oscplate_commandline.html. I recommend following the tutorial exactly to avoid any issues. Also, I recommend first getting this tutorial to run on your local machine before running it on your HPC cluster. Once you get the known tutorial running locally, then the HPC run can be debugged.nCan you give some more details on the local HPC? Does it have a job scheduler or do you have access to all nodes?nSteven
