November 30, 2020 at 4:51 am
nIf a Face has 64 nodes on it, then there will be 64 springs to ground created for the elastic support.nIf you add a spring to ground to the same face, there will be one spring created with a rigid spider to the face. However, the spider can be changed to deformable.nThe elastic support is always perpendicular to the face. A spring attached to a face can go in any direction.nThe elastic support spring rate is N/mm^3 while the spring rate is N/mmnThe spring can have damping, but the elastic support cannot.nThe spring can have a preload, but the elastic support cannot.nThe spring can be defined between two points, so it has a length. The elastic support is only defined as a spring rate.n
