Face collpase limit should be more than 0.5. nPlease check surface mesh skewness. If it is 0.5 then it should be good enough to generate volume mesh. nPlease see help manual for more details about these commands. nn
New Post - Reply To: Improve Surface Mesh in fluent meshing
