November 30, 2020 at 9:29 am
STEP or any other neutral format like iges etc. will always export two faces. nSuch faces can be connected together to give only one face by using command 'share topology'. Once share topology is used then meshing will have only one face. nIf you export STEP after share topology, then also it will have 2 faces. nPlease see help manual for more details about these commands. nThere are several videos available on share topology. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
