There's the SUM option in reporting, and that looks to sum the facet values on a surface. You can also get the facet average of the same scalar. If you divide one by the other does that give the number of cells, or a close approximation? I'll leave you to see what happens on a post processing line as that's not technically part of the mesh: a flow boundary or interior edge is. n
