You probably want layering. Then use a UDF to define the rate of motion of the wall. However, if you're assuming the freezing front is flat you can probably ignore the ice bit and just move the wall into the fluid region? n
New Post - Reply To: Dynamic Deforming Mesh: A Shrinking Zone
