Rameez_ul_Haq
the elastic support makes the scoped face as rigid or deformable? Is there a way to change that?nHow can I input a correct foundation stiffness for the elastic support? Can you give an physical example for me of each to clearly percept in which case elastic support will proof to be fruitful and in which case spring connection can do the work?n
