What boundary conditions are set? A zero residual can occur if nothing happens, ie zero flow over a boundary means there is no flow so the change is zero etc. It typically sorts itself out after a few iterations. Turning the monitors checking off can bypass the problem but it's best to understand what's going on too. n
