November 30, 2020 at 3:02 pm
nGo to the 'Solution Information', select 'Post Output' to check the error messages. You might need to add FILE command at the start of the post commands to specify the data file where results to be found.nEg:nFILE, Fname, Ext, --nnFname:nFile name and directory path. The file name defaults to Jobname.nnExtnFilename extension.nIf Fname is blank, the extension defaults to RST (for structural, fluid, or coupled-field analyses), to RTH (for thermal or electrical analyses), or to RMG (for magnetic analyses). For postprocessing contact results corresponding to the initial contact state in POST1, use the RCN extension.n
