Govindan Nagappan
Hi Array nUnder the first body, use the command to store the matid:nsolid_1=matid (under body 1)nCreate a named selection with all the bodies that should have the same material. For example: named selection is called my_bodies. You can insert this under analysis branch(static structural, modal etc)n n /prep7 n cmsel,s,my_bodies,elem           ! Select the elements in named selection called my_bodiesn emodif,all,mat,solid_1           ! Modify the Material for all selected bodies(elements) to solid_1n allseln /Solun n Let me know if this answers your questionn n
