nWhen you insert a Joint, and give it a Type, a coordinate system is created under the joint definition. If you expand the outline of the joint, and click on the Coordinate System, you can use the tools in the Coordinate System section of the Ribbon to reorient the free axis of the joint to be the direction you want.n
