You have 2 bodies and 2 parts. So it is non conformal mesh between two bodies. nMake sure you have Type as 'interface' for the faces between two bodies. nIf you want conformal then you will need to create a single part for 2 bodies and use share topology. nPlease see help manual for more details about these commands. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
New Post - Reply To: Why is the fluid not entering the inner domain ?
