Yes: use the particle summary file for that surface. Not sure what you meannYes, using the summary, but that won't pick up the particle-particle collision. You may need a UDF for that.The rapid acceleration is caused by the time step being big enough (and is therefore too big) that the particle overlaps with the collision partner. The solver then calculates the energy based on the overlap & therefore the speed. n
