Stephen Orlando
Hi,nThis isn't possible yet, but you could run the case from the Command Line Interface (CLI) and use some Python login in the run.py file to delete files as the solution progresses. A tutorial on the CLI is here https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v202/en/sysc_tut/sysc_tut_oscplate_cli_fluent.htmlnSteven
