Keyur Kanade
Why do you want to change default values?nIt depends on geometry and the location where these faces above 0.5 are. nPractically I do not change default values for surface mesh improvement. nCreate a small box. Create surface mesh for the same. Then use collapse command to see visually how it works. This will help you. nPlease see help manual for more details about these commands. nRegards,nKeyurnGuidelines for Posting on Ansys Learning ForumnHow to access ANSYS help linksnn
