You'll need to register for the Portal, and the option is just under the login part. However, if you click on Help in the software it'll bypass the password section and let you into the documentation (not the wider Portal site). n
New Post - Reply To: How to automate Fluent simulation: First 100 iterations are steady case and next 1000 are Unsteady?
