Govindan Nagappan
nFor default mesh sizes, you do not have to define a mesh size parameter. As you change & update the geometry, the mesher should come up with the default size based on the geometry sizennIf you want to specify and control the mesh size, then define a size control on the body or faces and you can parametrize the mesh size
