Daniel Shaw
The Command Object will not trigger a plastic solution, but it appears that there might be a restart. Is that true? If so, were plastic material properties defined in the original analysis? You could place a Command Object in the tree and just before the solve issue MPLIST,ALL an TBLIST,ALL to check the material properties just before the solve.n
