Turn off Distribute Solution from Advanced Solve Settings to see if the model runs. If yes, you need to install Intel MPI for Distribute Solution. MPI is the message passing tool to transfer data between CPU cores.https://forum.ansys.com/discussion/comment/94978#Comment_94978
Hello, nI too am experiencing the same problem regarding the 'unable to display results'. Where do I find the option 'Distribute Solution' from Advanced Solve Settings?Your help is deeply appreciated. n
