December 2, 2020 at 8:09 pm
I run the same model on a computer with 32gb RAM and it runs perfectly fine... I'm not sure it's a RAM issue as I've tried a model with less cells and it still was not running correctly. Rob, what do you mean by page to disc?https://forum.ansys.com/discussion/comment/99090#Comment_99090
Yes can work but you are at the limit. Can you perhaps try launching in batch on the machine? Is the definition file on that machine and the working directories is local? Can you try starting with large problems definition turned on? Please paste some more context of the outfile.n
